1 - 20 of 20 Posts
140463
today brake light lamp is showed up on my dash board. So I changed the rear light that was faulty and it’s still on. What do i do?
Like being in a warm bath of Rotella.
That might be a little harsh on the skin. We used to play in the mud with no side effects.
140472
Reactions: ConrodM
2008 Honda Pilot EX-L
Did you use a regular Halogen bulb for the replacement? If not and you used an LED, likely need to add load resistors for that not to be on.
He's posting from Nigeria (see the little flag). Pilots are not native to Nigeria. It could be the beginning of a beautiful friendship which leads you to inheriting from a prince (with a small catch). It keeps happening from time to time.
He could have got his Pilot through Somalia. Why assume every one is up to no good?
smirk
Reactions: Daltongang
smirk
I've recently inherited a fortune from the Ice Queen of Canada. But I've run into a tiny hiccup in that it's currently frozen. If you'll just send me a Western Union for the taxes owed and administrative thawing fees, I'll split it with you. :p
Super Moderator
While the Pilot is not marked in Africa they are available. There are several available for sale in Nigeria alone.
Here in South Africa:
As well as Ghana and the Middle east.
The middle east is a Honda target market since 2017 for the Pilot.
I also do not see where the OP is banned. So folks let's cut out the snarky comments as to the OP's location and stick to the subject please.
Seansolex It would be helpful if you would post the year and model of the Pilot you are having issues with. Welcome to the forum.
I see OP's status has reverted from Banned to Registered.
OP, how old is your battery and what does it measure with a multimeter?
Loose wire?
I'm talking about the ABS.
@Seansolex Have any of these suggestions helped? Has the problem been fixed or is it still there?
Looks like the forum's initial banning algorithms were correct.
1 - 20 of 20 Posts
