Just follow what your owner's manual says. People usually do it every2-3 years. It is important to flush the brake fluid out because it tends to gather moisture and that's a bad thing for your brake fluid. New fluid should be clear and not look like used motor oil.
What the last poster said. And brake fluid maintenance is really fairly independent of brake pad maintenance. One is more a calendar item, the other a wear item.
This is one of those things that everything will be all right until it's not all right, your ABS light comes on in the dash, and you'll have a $3K repair bill for a new ABS pump (or other high-ticket item). Not something to skip lunch right now and go do, but get it done at your next service.
I honestly don't know what dealers are charging, but my guess would be $50 or so for a half-hour of work. An independent will be cheaper (this isn't rocket science) and I'd try and work it into a regular service or package of services.
Yes, Honda recommends its own brake fluid for Pilot.
You should be able to do it without taking the tires off. But it may require that you bleed/change the brake fluid in a certain order. And you may need to disconnect the negative battery end to disable the ABS. Since I don't have a service manual, I can't be sure. But it is at least true for some other vehicles.
If Honda does recommend their own brake fluid, I'd view it just like they're recommending their own oil - they simply want to sell you their overpriced stuff. Unlike the ATF and VTM situation, there is nothing unique or special about the brake fluid spec - just plain old DOT3 or DOT4.
Use DOT4 which is, by spec, absolutely compatible with DOT3, but has a higher boiling point. I'm sure any quality fluid would be fine, but a bunch of sites have recommended Valvoline SynPower DOT4 so that's what I use. I'd buy the bigger 32 oz size as you'll probably use most of it.
Always dispose of brake fluid carefully - the stuff is really nasty to the environment if you pour it down a drain or dump it on the ground. Most autoparts stores will recycle it. I store it until a twice-yearly recycle day put on by the local community. You need to keep it separate from AF, oil, solvent, etc.
Another recommendation you'll hear is to always use an unopened brake fluid container. I think this is complete overkill. While you do want to keep the container tightly closed between uses so as to not continually circulate moisture in the the container (where it can be absorbed in the the brake fluid), the amount of water vapor in the small parcel of air in the opened brake container is absolutely miniscule - if you want to worry about this, then you should also do your brake bleed in a vacuum wearing spacesuits.
I think Honda wants you to work from the wheel closest to the master cylinder outward.
That is correct: (1)front left (2)front right (3)rear right (4)rear left
I just recently did a brake overhaul (rotors, pads, fluid) and it was a lot easier than I thought. IMO, unless you have access to a lift, I think it would a PITA to gain access to the bleed screws. Besides with the wheels off, you can do the common visual inspections that the dealer would do as part of a service package.
Why DOT 4 when the recommended is DOT 3? Dot 4 has a higher dry and wet boiling points for high temp situations, while DOT 3 is less susceptible to hydroscopic issues, meaning it doesn't need to be changed as often. Also the addition of borate esters in DOT 4 can be harmful to some of the components in a DOT 3 designed system.
We use it for longer trips (usually mountain areas) with 4 people and luggage. I'll sacrifice a little hygro for the higher heat rating. I'm in florida and Florida drivers suck. People flock to the left lane without looking and I have to stab the brakes. Not much water will be absorbed when flushing every 3 yrs.
Related Threads
Honda Pilot - Honda Pilot Forums
815.6K posts
155.4K members
Since 2002
Piloteers.org forum community offers tech info, troubleshooting, modification DIY’s and discussion for the Honda Pilot SUV.
