I need to mount a tekonsha prodigy 2 brake controller. I’m trying to decide the best place to mount it in our 2015 pilot so it’s the least obtrusive. Where have some of you mounted yours?
in the steering column located there is a port that connects to the brake controller. Tuck the bugger up inside the dash if you like behind those plastic crap we call panels there is lots of room.
2013 Touring 4wd
Being a short guy, I figured installing it below the steering wheel column area should be a good location. NOT!
I have relocated it to the left side spot where the parking sensor switch and traction switch are located. WAY better area imo.
140721
