I'm having a problem with my vents on my 2010 Honda Pilot EXL. When I turn on my A/C the middle vents don't blow any air and its just stuck on the feet vent. After searching it looks like its the Blend door actuator, the only thing is that I don't know where is it located. Does anyone know where is it at?
Here's the one I replaced, it was clicking so easier to find
I would look at the operation of the mode motor. Check out this thread: https://www.piloteers.org/threads/vent-air-mode-issues-mix-motor.91178/
You can remove the dash panels on the passenger side with basic tools and then view the mode motor as you try and cycle through the positions. If it isn't moving then I would suspect the motor needs replacement. Download the repair manual from the sticky if you don't have it already.
