Well, a few weeks ago I'd promised I'd write up the procedure for bleeding the brakes on the Pilot with the Motive Power Bleeder.
I've been using mine on all my cars for years, but hadn't done the Pilot yet, or used my Motive 1101 universal adapter. Well, I did the job, and was successful- no problems whatsoever.
So, without further ado, here's the procedure.
(disclaimer- don't do this without the proper tools and experience. The procedure is documented for illustrative purposes. This is merely how I did it. I cannot guarantee that following this procedure won't kill you. You have been warned.)
Now with that out of the way.
What you will need:
What you will need:
- All the usual stuff for jacking up and removing tires (jack, jackstand, 19mm socket and breaker bar, torque wrench)
- 10mm combination wrench (I prefer a 6-point box end)
- Motive power bleeder tank and pump kit
- Motive 1101 Round Universal Adapter
- Motive Bleeder bottle (optional), or some other reasonable substitute (I made my own)
- Turkey baster, one that you will never ever use for food again. I like going to the dollar store for this.
- 1 Quart of brake fluid, Minimum spec is DoT-3, I happen to like Valvoline DoT-3 & 4 or Castrol LMA. They say synthetic on the bottle, but note that ALL brake fluid is synthetic. I usually buy a second quart just in case, and use it on another car if I have to.
[/list=1]
Raise the front of the car and support both sides with jackstands and remove the tires.
Remove the brake fluid cap and set aside. You can disconnect the plug if you'd like, but there's enough slack to tuck the cap aside. Wipe it down with a clean cloth before, however.
Remove the filter basket under the cap and set aside. Wipe it down with a clean cloth.
Use the turkey baster to suction out as much brake fluid as possible. You're only going to be able to remove all the brake fluid from the front circuit. The rear circuit will drain about halfway. If the brake fluid is 2.5 years old, like mine, it should be a dark amber color.
Refill the master cylinder with clean fluid from an unopened bottle.
Now, attach the Motive 1101 Round universal adapter. The chain goes around the bottom of the master cylinder. I put a little clean brake fluid on the rubber insert to get a good seal. Do not overtighten. You don't want to crack the reservoir.
It'll look something like this:
