Hello! Does anyone happen to have the part numbers for the Pilot black edition moldings or window trim? Not having any success searching online or on the forum. My goal is to replace all the chrome around the windows with the black edition trim.
Thanks in advance.
Abe
2019 Pilot EXL AWD
Thanks in advance.
Abe
I am not sure where you are located, but I was told by my local US dealer to contact a Canadian dealership as he said they were not available in the US. He also mentioned that it is not a easy replacement and the very rear windows you actually need to replace the glass as they come as one piece (the glass and the trim). It is simply not a "sash trim" piece. There was also an issue around the side view mirrors having to replace the mirrors or fender or something more involved than just popping off a trim piece. I know that's not what you asked for and maybe you already knew that, but I was researching that same option until I got that news. Good luck!
Better to wrap with 3M or Avery. Vvivid+ is too thick. I could not get the rear window trim perfect because the tolerances were too tight to tuck and I didn't have the skill to cut it close enough to the edges to keep any chrome from showing through. The trim along the bottom edge of the door can be popped up for a solid wrap and the corner piece in front of the mirrors pops off so you can extract the chrome metal from it and do a tidy wrap. I do recommend removing the side mirrors to do it right.
