Anyone on here trimmed their wheel wells to get bigger tires on the Pilot I would like to put 31.5in tires 265/65/18 tires on the Pilot. Please post pics
Do your research before buying tires. Different AT tires have different profiles and sizing and therefore fit differently. Just because Coopers fit, doesn't mean Falkens will. Ideally, you verify before commiting.
Also, wheels have different offsets. Be very clear when you confirm fitting: a stock wheel will have different fitment with 55 mm offset vs typical 30-38 mm aftermarket.
Keep in mind that lifting typically increases rub on a tire that used to fit just fin before.
If you want to avoid cutting metal, check out Traxda axle relocation kit. They managed to fit 32.1 tire with minimal plastic trimming.
