1 - 18 of 18 Posts
2005 Honda Pilot EX-L AWD
So I mounted 32” tires in the rear with a lift and I’m getting ready to do the front because the AWD system and the computer are having a fit over different wheel speeds. Because of this I’m moving forward on getting front wheels sooner but the only problem with rubbing I have is that the struts hang over the tires which means bigger wheels will rub. I’m ok with doing spacers but I was wondering if anyone had experience with struts that aren’t as wide over the tires.
Spacer are probably the only way to go, unless you can get a custom made front strut and coils. Also even with spacers wont your tires be rubbing at the wheel well when turning?
I picked up a set of used Blizzak 255/70/16 (couldn't let it pass for $250) and its already pretty tight, no rubbing though.
Super Moderator
Wheels with less positive offset will shift the wheel+tire combo further away from the strut otherwise spacers will be the solution. Select quality hub-centric wheel spacers for best results.
I'm in a mood tonight. I just watched 'The Last Motorcycle on Earth' on Amazon Prime.
Whether you ride or not, you should see this. It's coming.
So, I have to say:
Why? It's a Pilot. That's like stretching a Honda Grom! LOL
I realize you have the right to do whatever you want, for now.
245/75/16 is 1.5" shorter than 32s. Big difference. With 20MM spacers, will you have enough thread left on the lug bolt?
Good spacers don’t go in between the rim and brake rotor, they essentially bolt on as if they were the rim then the rim bolts to the spacer as if it was the rotor.
So, I have to say:
I mean I use my Pilot and get through mud just as well as some custom built jeeps do, that was also on highway tires. My Pilot does a fine job and I do what I can with the money I have. I’m still in Highschool by the way.
Not true......it depends on how thick the spacer is. For example, the rim is not going to bolt to a 1/4” thick spacer. Just a heads up, high school is 2 words and not capitalized the way it was used.😉👌
Lol, but look at all that snow he's able to get though out behind the vocational wing of his high school.
Well, Welcome to the forum young man.
I did a LOT of things when I was in H S, that I wouldn't even consider now.
Bigger tires/wheels- definitely a high school thing FS.
Not bashing you at all. Nothing wrong with what you're doing either.
1 - 18 of 18 Posts
