Hi! Today we discovered that our 2010 Pilot’s battery was loose. It appears that one of the bolts won’t tighten and another plastic piece is broken. How easy is it to replace? Is there a place to find a diagram of the engine compartment so we can look at it specifically? Thank you!!
It sits on a tray on the driver side towards the front of the car. If you remove the front section of the air intake (two clips and wiggle out IIRC), then it is easy to access.
Not sure what you mean by loose. If the cables are loose, then you can buy spacers. If you mean the hold down bar than you can probably replace the screw. The only plastic I recall was the positive cover flap and a shroud that slipped over the battery which doesn't matter.
