If your aftermarket GPS was connected to an always hot/on circuit that could explain why you had the problem of the battery draining.
If you need to reconnect it permanently you could hook it up to a switched circuit (one which is energized only when the key is turned in the ignition).
Glad you found the cause of the problem.
21 - 24 of 24 Posts
