Just recently noticed that the guidance lines for the backup camera have disappeared from the navigation screen. I can’t figure out which sequence of buttons to press in order to get into the vehicle settings screen. Has anyone had this similar problem and know of a solution ?
Turning head and using your eyes not considered?
Reactions: Tahoefever
Maybe it's one of those situations where they need to sit on a box to barley look over the steering wheel?
132361
“The audio/information screen can display your vehicle’s rear view. The display automatically changes to a rear view when the shift lever is moved to R.
To turn the guide lines on or off, press and hold the RETURN button for about three seconds.
If you turn the guide lines off, they remain off until you turn them back on.
Rotate to adjust the brightness of the rearview camera. If the camera lens is covered with dirt or moisture, use a soft, moist cloth to keep the lens clean and free of debris.” [p.369]
so this all packs up to RTFM ! :p ... nice
This worked for me too.
"o turn the guide lines on or off, press and hold the RETURN button for about three seconds."
Thank you
