1 - 8 of 8 Posts
I want to install a backup beeper on my 2011 pilot.
When I back out of a parking space at the store it seems like someone is always walking around behind me. I guess they can't tell that I'm backing out. I want to have an audible warning backup beeper.
Please help me.
Get something like this:
Find a spot where you want to mount it. (Probably somewhere around the hitch)
Run the wires and connect it to one of your reverse lights.
Thanks Ok.
I've got one of those but I don't want to cut up my wires. Is there a good place to make a connection without cutting any wires? Like a separate or auxiliary wire harness?
Premium Member
Miss our 2005 Pilot
Use Posi-Taps if you don’t want to cut into your factory wiring.
Yeah, just put some kind of T-taps on the wires going to the reverse bulb socket.
P.S. and yeah, if you got a towing harness, you can tap that too.
Thanks Ok.
Back Right side above the speaker you will find the wires for the reverse light, Connect to these wirels.
1 - 8 of 8 Posts
