Does anyone know if the door catch on the doors are ajustable?
Striker is.
I know the striker is. I had a hard-to-open/close driver side door and the mechanic adjusted the striker to fix the problem.
Good luck.
Door Striker
The catch (striker) is adjustable. The procudeure is to loosen the two screws holding it to the body. Slide a shop towel between the striker and the frame. Lightly tighten the screws. Tap the striker lightly to adjust. Use a plastic or cloth covered steel hammer. Loosen the screws remove the towel, lightly tighten the screws and test. Keep going until it works, tighten the screws.
