Here are some more "detailed" instructions on how to do this mod that I put together. This turns off the Auto Idle Stop System by default and lets you continue to use the button to turn it On and Off as usual. You do not loose any functionality, it is just Off by default instead of being On by default.
But first, lets give credit where credit is due based on the posts I have seen.
RGVPilot was the first to post an idea on doing this. This method may have worked but it was basically simulating a stuck switch and that really isn't the same as what we see here.
Permanently disable Auto Stop Start!
Recently, cvcy24 posted this method but used a different board that shows out of stock.
Made an Automatic Auto Start/Stop Disabler DIY
I wanted to use a method where the parts were easy to get and the module used has been around for some time now. Do this at your own risk and I am not responsible for anything that goes wrong. My method does use a fuse so the chances of anything going wrong if you follow these instructions should be very minimal if at all. While this does give a lot of step by step detail on how to do this, you should have a basic understanding of what you are doing and are comfortable working with electronics and wiring.
This modification uses the commonly found FRM01 module. At the end, are the current links for the parts used.
Details of the Modification
Pin 1 (Green) is the 12v terminal that is active in Accessory and Run mode.
When pressing the Idle Stop switch, Pin 1 and Pin 7 (Yellow) are connected momentarily. When releasing the switch, this connection is broken.
This modification is simply just duplicating the momentary button press. The button continues to function as normal but the Auto Idle Stop System is automatically turned off 5 seconds after entering into the Accessory mode.
Using jumper wires (18 AWG Recommended) connected in parallel to the wires on the plug, connect them as follows.
Pin 4 (Black) connects to DC-
Pin 1 (Green) connects to DC+ and COM using a 1 Amp inline fuse as shown below.
Pin 7 (Yellow) connects to NO
When the relay activates, it will connect the COM (Green) and NO (Yellow) wires together for 1 second.
The module needs to be set to Function #3 for this installation.
1> Long press [SET], enters into [Parameter setting mode];
2> Short press [SET], until the [MD] indicator light is on if not already, press [NUM+] or [NUM-],
adjust the digital tube display to "- - 03";
3> Short press [SET], T1 light will be on, press [NUM+] or [NUM-] to set T1="0 0 0 5", (5 second count down after it receives power)
4> Short press [SET], T2 light will be on, press [NUM+] or [NUM-] to set T2=”0 0 0 1”, (Relay is on 1 second simulating pressing the button)
4> Long press [SET], this saves the settings and exits [Parameter setting mode], the function starts running immediately.
Removing the center panel to access the wiring for the modification.
If at some point this link becomes unusable, just search for FRM01 to find a new listing.
(FRM01) DC 12V Programmable Multifunction Time Delay Relay Module with Segment LEDs Display & H/L Level Trigger
https://www.amazon.com/gp/product/B07BT32T1M/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Here is a link to a case that is currently available on Ebay if you would like to mount the module in a case.
https://www.ebay.com/itm/Case-For-FRM01-Relay-Timer-Module-More-Enclosed/172550623624
18 Gauge Fuse Holder for Regular Standard Blade Type Fuse
https://www.amazon.com/KOLACEN-Auto...1&rnid=2470954011&rps=1&s=gateway&sr=8-3&th=1
1 Amp ATO/ ATC fuse
https://www.amazon.com/Blue-Sea-Sys...way&sprefix=1+amp+,aps,198&sr=8-15&th=1&psc=1
- Remove Front Rubber Mat
- Remove Center Console Panel by first removing the two screws.
- Next, open the center console and lift up firmly at the center edge of the panel. The clips shown below will pop out as you lift up.
- Put a soft towel down over the center console where you removed the panel from and flip over the panel to give you access to the wire plug. Currently there are two options to connect the wires to the plug. You can use Quick Splice connectors on the wire itself, but this will leave small cuts in the insulation if you ever remove them later. Or you can just strip back the ends of the new wire, fold it over on itself and then insert it down into the connector along side the existing wire making a tight fit. Make sure the wire is making good contact with the pin inside of the connector. Once the wires are all inserted, use a zip tie or electrical tap to secure them in place so they won’t fall out. I am still trying to locate the factory connector(s) to see if they can be purchased and make this more plug and play. Secure the board to the bottom of the panel making sure nothing will get shorted out. Using the optional case is more insurance that this will not happen. Do a final test to make sure everything is working and install the panel in the reverse order.
1 Amp ATO/ ATC fuse
