Pilot 2013:
If ATF level is showing at bottom marking when read hot per manual, does anyone know what additional volume of fluid brings the level to the top marking? I want to top up to halfway, but not overfill.
Pilot 2013:
While it is important not to overfill, being overfilled a small amount has not proved fatal. Not knowing exactly where you are on the dipstick, I'd simply add a 1/4 to 1/2 quart to try reach the desired level. I'd rather be a little over than low.
Reactions: The Todd
Sounds good, as that's what I was planning. I'm going to do a D&F this wkend so I'll start with increasing +1/4 Qt vs what comes out and see where I land.
The las time I checked my 08's ATF- Not hot- it was slightly over the tope Dot/hole! It was bright red. I'm not worried, it whifts fine @ 195K miles LOL
Reactions: Nail Grease
