1 - 16 of 16 Posts
I have a 2016 EX-L with 54k miles now and have the same rough, loud suspension some of the folks on this forum have raised. I have come to the conclusion that the factory shocks and struts are bottom of the line and having the dealer replace them will just result in the same quality put back in. I was wondering if anyone has done an upgrade or gone air ride or bags to soften the overll ride.
I looked at KYB, Bilstein, Monroe, Strutmasters and none of them have any solutions for the 3rd generation Pilot. Has anyone found a suitable option that softens the ride? Hoping someone can offer any suggestions. The current rough ride quality is just not going to work long term.
Thanks in advance.
Looks like for now we are screwed. This SUV would be really good if it were not for the annoying suspension components. Road noise and clunking sound over bumps sucks. I hope someone comes up with a solution soon.
I don't know what to suggest other than buying another type of vehicle if you want to soften the ride. If anything it needs to be a little more sporty on the suspension side.
I have a 2016 EX-L with 54k miles now and have the same rough, loud suspension some of the folks on this forum have raised. The current rough ride quality is just not going to work long term.
What tires are on your Pilot?
I am looking to get adjustable shocks so I can soften the ride when desired. My wife is the primary driver and she has a bad back with a couple of degenerated discs as well as a bad hip. If I can get a kit with a "comfort mode" setting that would be ideal.
With regards to Tires, I have Michelin Pilots on it. I'd have to check the size but I know its not 20". If we can't find anything then the next option is to replace the car with adjustable suspension. We really like the 3rd row seating and leg room in the Pilot which can't be matched by too many other cars. I drive occasionally and I am 6'5. Thanks for the feedback (y)
If you want softer suspension, get 17 inch wheels and put less air in your tires ( regular all season tires). This will give you more cushion but might add a little more wobble when taking corners at high speed. 18 inch wheels should be better too, so if that's what you have, try various air pressure settings.
The downside of running lower pressure is worse fuel economy and premature tire wear.
Replacing the suspension on lower models with Touring / Elite suspension is one option. Due to the 20” wheels and lower profile tires, the Touring / Elite models have a softer suspension to compensate for the less compliant tires.
I checked the parts catalog quickly, and your statement doesn't appear to be true. The shocks, springs, and other suspension parts are the same identical Honda part numbers when comparing a 2018 Pilot Touring AWD with a 2018 Pilot EX AWD. Even though these two models have different size tires, different transmissions, and different equipment contents, there IS NO difference in suspension parts that I have found. I would venture to say that is true with other years and model trims in the 3rd generation Pilots.
There is a difference between AWD and FWD on some parts that I checked quickly (springs) but they are the same within the AWD or FWD models. You really don't want to put FWD springs on an AWD vehicle, and vice versa.
Could you expound on your statement and provide proof that spending large amounts of money to change suspension parts will provide a different ride when buying Honda parts for a Touring/Elite model to install on a lower trim model? How have you decided that the Touring/Elite models have a softer suspension to compensate for the less compliant tires?
Changing tire brands and sizes as already mentioned would be the best way to change the suspension ride and handling. You could also replace suspension parts with aftermarket parts as the OP has mentioned in the original post.
So typical on so many automotive forums. Members who are self proclaimed "experts" posting incorrect information.
I have a 2016 EX-L with 54k miles now and have the same rough, loud suspension some of the folks on this forum have raised. I have come to the conclusion that the factory shocks and struts are bottom of the line and having the dealer replace them will just result in the same quality put back in. I was wondering if anyone has done an upgrade or gone air ride or bags to soften the overall ride.
Thanks in advance.
Have a 2011 Pilot Touring with AWD. Have had suspension problems (shocks and ride quality) since the beginning. Had replaced the rear shocks with the KYB model (which I now hear that it is the same model as the stock one) and found little improvement. I had the fronts struts replaced under warranty at 45,000 miles after complaining that the vehicle consistently lost its rebound (jounce) control after going 200 miles on a 300 mile trip. Again, the factory struts were marginally an improvement. I have been looking for replacement Bilstein or Koni shocks for years and late last year, finally found them at Tire Rack.
By then, I have had over 120,000 miles on the Pilot and the shocks were failing again. Ordered the sport struts and the sport rear shocks from TireRack. Looked for progressive springs for the vehicle, but it appears the the aftermarket suppliers do not consider the Pilot heavy duty enough to manufacture a line for it.
I recently had the struts and the rear shocks installed. The ride is now heavy, dampered and controlled. It is smoother than ever and the combination with the original springs seems to be compatible so I have decided not to replace the springs.
Even though the Bilstein struts and shocks are the sports model, the ride is smoother than the stock set up. I would wholeheartedly recommend this set up for the Pilot of my series.
Which bilstein shocks did you end up going with? And they should work fine with the combination of a ready lift kit correct?
New to Piloteers. Thought I would post this info. pertaining to the same harsh ride from the rear suspension that we have also noticed. Bought my wife a certified 2018 Pilot EX-L last summer and just changed the tires out which "has helped" but not fixed the harsh ride in the rear of the Pilot. The new tires, which had to be test fit by Discount Tires first,.. to make sure the fronts didn't rub while turning, are Continental Crosscontact LX 25, size 265 / 60 R18. These do throw the speedometer off by 2 mph but we didn't care. The ride has improved, but again hasn't fixed the problem entirely. The Pilot sits 1" higher and the tires look better than the stock size,..our opinion. I am also looking for aftermarket Struts that will entirely fix this issue. All and All the Pilot is a good SUV.
Sorry but your only sitting 1/2" higher then with the OEM's. You have an axel in the middle of that overall tire diameter so only half of the additional circumference would be on the pavement side.
Have you addressed the shocks themselves. Are they leaking/in need of replacement. Keep in mind this vehicle is not designed to ride like a Cadillac. It is after all built on the same basic frame that the Passport and Ridgeline PU is built on.
Glad you like the look.
I would start with trying different tire pressure. I think 34 PSI is what's recommended. Try 33 and 32. You will feel a slight difference.
Next, you can try a different tire. Continentals that come stock are loud. I had Blizzaks and now have Copper Discoverer ( both were mounted on 17 inch wheels) and both are quieter than stock.
I have to admit 17 wheels give you more room to play with different pressure settings to find the right comfort level. I am sure 18s will be better than 20s too.
As far as shocks, unless you order custom shocks from manufacturers like King (maybe others), there is not anything on thearket yet. The car is too new and it seems that it is not customized as much as others car and trucks out there.
Good luck.
1 - 16 of 16 Posts
