Anyone do any mods? Air filter or anything at all?
SHARE!!!!
SHARE!!!!
Wow... where to begin. Most members on here have been very helpful and gracious with their information (ie MDX subframe braces) and I don't want to flame anyone but sheesh.Scancord said:My friend is very good with car mods, especially Honda and Acura.
3--Place thermal spacers between the manifold and engine frame. My friend did this to his Piot, and it gave him better pickup, since it kept the engine running cooler. The make a kit for this mod, he did it in his 04, I have an 08, I will try to do it myself.
4--Take the plastic engine cover off. This cosmetic cover retains heat and once removed, let the engine breathe better.
BF
LOL, I was waiting for a Turbonator thrown in to really make the pilot fly!.:2:Flyimports said:
Engine frame? What? Engine running cooler? Do you mean a cooler intake charge? Maybe you mean a thicker intake manifold gasket?
Plastic engine cover = letting the engine breathe better? Not related. Not even with seven degrees of separation with Kevin Bacon. Put it back on.
Please dont let that guy take any more of your money.
K & N Filters are pure marketing cack. It is physically impossible to let more air in AND filter better. Any performance gains are at the expense of letting in more silicon grit or other contaminants, which are bad for the wearing parts of your engine (bearings, rings).Scancord said:1--Insert a K and N air filter. Better throttle response
Huh? Unless your vacuum lines are actually leaking, the only advantage to silicone is durability and heat resistance. Are you implying that under high performance conditions, the vacuum lines actually deform enough to have an effect on performance?2--Change the rubber vacuum lines( about 3) to silicone tubing. This tubing does not flex as much, once the Pilots computer gets used to it, you get better throttle response. It does work, I did this to my Accord too.
Excessive temperature in the intake can lead to elevated engine temps and decrease performance (which is why so-called Cold Air Intakes are cack, since they usually take their intake from the hot engine compartment than outside air) . I fail to see where this would have a measurable effect on performance unless there were something already wrong in the first place (such as the cooling system failing to cool effectively to begin with).3--Place thermal spacers between the manifold and engine frame. My friend did this to his Piot, and it gave him better pickup, since it kept the engine running cooler. The make a kit for this mod, he did it in his 04, I have an 08, I will try to do it myself.
1/8" of plastic is hardly thermally insulating.4--Take the plastic engine cover off. This cosmetic cover retains heat and once removed, let the engine breathe better.
So far, this is the only sensible thing you've said. I don't think Mobil 1 would add any appreciable performance gains, but it does provide some advantages insofar as being viscosity-stable, and additive package-stable over long oil change intervals. A quality filter is good peace of mind- I'd rather spend a buck or two on a better filter than a cheaper one like a Fram, because the better ones (Wix, Purolator, Mobil 1, etc) are simply assembled better, and have better QC.5-Use Mobil 1 5-20 Extended performance Oil--its the best, by far
and a Mobil One Oil filter
However, a relabeled Fram product is not the only choice available in an oil filter from the Honda dealer.ctobio said:I generally don't like OEM filters from the dealer counter, because they're a real crapshoot, as you saw in Tom's post. Exceptions are at the German dealers, which nearly always use Mann, which produces a high quality filter.
Given the oil filter change interval on the Pilot is every other oil change, I don't see how they can, in good conscience, sell relabeled Fram filters.
Right, but what are you going to do? Open up every box and go "Nope, that's a Fram. Can you pull another off the shelf?"xGS said:
That'll make friends fast with the counterman.
You must be a horse.I cut a hole in the floorboard so my feet can reach the ground and I run like Fred Flintstone! Worth an extra 1hp!
There is a never ending thread on doing just that over on MDX site. All promise no product for several years afaikIt would be nice if we could get an improved J Pipe. I did a similar mod a several years ago on a V6 Contour and the improvement was noticeable.
