1 - 16 of 16 Posts
My car (2008 Honda Pilot) was making a lot of noise under the hood. I took it to two local mechanics and they told me I needed a new engine. I ended up taking it to a Honda dealership and come to find out it was the timing belt tensioner. They replaced it, which fixed the issue. Well, I went to pickup the car this morning and now it's making a very faint noise for 2-3 seconds when I start it up. It goes away, but I have no idea what it is. Anyone have any idea? Here's a video showing starting it up a few times:
That sounds like a pulley bearing loose and vibrating upon spin up. Take of the serpentine belt and check the belt tensioner and pulley to see it its wore out.
When my starter went out a couple of months ago, I looked into just doing the solenoid, but in the end the whole starter had to be swapped out for a reman.
Thanks everyone. Looks like it is the starter. Dealership quoted $750 to replace it. How imparitive is it to replace this immediately? Should I get replaced now or could I wait a couple of months?
Got to an independent trusted Honda mechanic. I paid $450 for mine. It was a remanufactured one but it works great.
I THINK if you continue with a bad starter, it’ll wear the battery out (don’t quote me on that).
$450 for parts and labor?
The starter was $202 (Napa Premium) and the labor was another $250 or so. I don't have the invoice in front of me but I remember generally. I also remember thinking it's worth paying someone else so I don't have to do it myself.
Rock Auto sells brand new TYC starters which are the same as OEM but cost a fraction.
It is a relatively easy DIY job. All you need to remove is the battery tray and use a cheater bar:
Below was the wrong video. The newer starters used 2006+ have bolts from the top rather than from the side.
that's a shame, the denso starter on my toyota has a removable cover for the solenoid, I've removed twice in 125k miles to clean and lubricate the contacts. I'm guessing the issue here is with the actual motor needing lubrication.
The honda starter can be taken apart since on the dealerships website you can order parts to rebuild the sucker
133223
Reactions: vwvannut
I’d replace the starter sooner than later to avoid getting stranded at an inopportune time.
If you’re semi-handy you can do this job in less than two hours. Toughest part for me was getting the two bolts loosened. Having a long breaker bar is key.
1 - 16 of 16 Posts
