Just bought Honda pilot 2019 and look like there is a leak at anti lock brake pump? Is this anti lock brake pump? it locate in the passenger side of engine compartment.
Yes, that is ABS modulator. Should be dry as a bone. I assume you are still under warranty....take it back and they should fix it.
If that is brake fluid, then you should be seeing your brake fluid reservoir level dropping.
Man brake fluid is some NASTY stuff! Just eating that metal like it's nothing.
Definitely a trip to the dealer for you. Can you tell if the fluid has gotten on anything else? Brake fluid is immediate failure for painted parts so I'd make sure nothing looks wet.
