1 - 2 of 2 Posts
A few days ago I received the message: "Anti Theft System, This system has lost power...". I figured it was a glitch, so I pushed the power button for a few seconds and the radio came back on. I received the same message this morning and again this evening and now I'm starting to worry. I did a search and I didn't really find anything. I'm just wondering if something could be wrong with the battery.
134205
Could be the battery but usually a bad battery causes other warnings also. Does this occur only when you start the car? If so, try powering up the infotainment in Accessory Mode (foot off the brake and press Start). If it doesn’t happen in Accessory mode but only when starting the car, a bad battery or faulty connection to the battery would be most likely the issue. Honda must have had an unusual number of AGM battery failures occurring as they started collecting failed batteries from Tourings and Elites about a year ago for investigation.
1 - 2 of 2 Posts
