2008 Pilot. I have removed everything, but the alternator just pilots forward and back like there is a bushing or something in the bottom bolt. I can't figure out if that is true or what else I am doing wrong! Help! Thanks!
Dandrade5409 29 posts · Joined 2019 Add to quote Only show this user #2 · Jan 3, 2020 Use a pry bar or screwdriver to pry it out
Wintermath Discussion starter 5 posts · Joined 2020 Add to quote Only show this user #3 · Jan 3, 2020 I got it out. Now that spacer is preventing the new entry of the alternator
Wintermath Discussion starter 5 posts · Joined 2020 Add to quote Only show this user #4 · Jan 3, 2020 Can't seem to make it budge at all.
C can 1812 posts · Joined 2015 Add to quote Only show this user #5 · Jan 3, 2020 They can be tight. Push it in with more force, or if you absolutely cannot then tap the bushings inward slightly.
Wintermath Discussion starter 5 posts · Joined 2020 Add to quote Only show this user #8 · Jan 3, 2020 Thank you!! I was able to force it in! Thanks for your help!
boom 607 posts · Joined 2014 Add to quote Only show this user #6 · Jan 3, 2020 Tips here: 2007 Alternator replacement
Wintermath Discussion starter 5 posts · Joined 2020 Add to quote Only show this user #7 · Jan 3, 2020 boom said: Tips here: 2007 Alternator replacement Click to expand... Thanks!! I got it done!!
