Once in a while my Airbag light will turn on and when someone is in the passenger seat the seat belt light will turn on then blink and beep as if their Seatbelt is not on. What should I do check to fix this issue?
Sent from my SM-G973U using Tapatalk
Get the trouble codes read. Most likely they are Honda specific so a generic code reader will likely not register them.
I would also check your passenger seat belt buckle. There may be debris inside there that is causing intermittent electrical connection.
I seem to recall there was an issue with earlier model Pilots and the passenger seat weight detector. You might check that too if that’s what you meant regarding the airbag light.
