I am curious. Did anybody notice changes after water pump recall fix.. I have the following issues:
1) Engine noisy
2) Less power
:8:
I have not noticed either issue
haven't noticed either issue, car runs the same as it does before, and I've got about 1,500 miles since the recall.
Here is a cut & paste from a reply Threadhead made to an owner with a similar issue.
Hope this helps,
Chris
quote:
Originally posted by torrys
They just completed work on my Pilot yesterday. Mine unfortunately was one of the Pilot's recalled with the bad pump. The car seems a little louder and it has less power since the fix (I can't squeal the tires from a stop). Has anyone noticed this or did I just get some bad service?
P.S. They said mine was the first one they did.
Take it back, ASAP! They probably slipped a notch on one of the cams when reinstalling the timing belt. It's easy to do (I've changed six Honda timing belts). If it is more than one notch, the valves could be damaged.
I had mine changed two days ago and I have noticed absolutely no loss in power. Sounds a little quieter but that's about it.
Can't guarantee that's your problem, but you should definitely get it back for a check out soon.
I agree, I used to do my own belt replacements on my VWs and if I was off one notch the car would run bad and feel like it did not have the power it did before I did the change.
I would take it in ASAP
Absolutely
Sounds like your valve timing is off. To reiterate, take it back el pronto!
Re: Absolutely
Hey Lite-
Let's have a look at the Millies you put on your Pilot-
