I snapped a bolt yesterday doing my rear brakes luckily it was the bolt that went to the caliper pin so it was a easy fix once I found the part. For some reason the 3/8 torque wrench never clicked. It worked all day and I over tighten the bolt and snap. I still have to do the front brakes and they have much torque. Any advice to limit this in future. I already just ordered a digital torque wrench from Amazon just incase.
I use inexpensive Pittsburgh from Harbor Freight. I have both digital and the mechanical dial and lock kind. No issues so far.
Reactions: briantii
Super Moderator
Don’t feel too special LOL The same bolt snapped on me and I use a torque wrench regularly for critical areas but not on those particular bolts. I suspect bolt fatigue as I’ve done the brakes multiple times in my old Pilot and a bolt felt funny while tightening then decided to snap and I don’t over tighten them. I’m just glad it was not a PIA to take the bolt out. Depending on where you live some people use thread locker while others in the rust belt swear by anti seize for those bolts.
That’s exactly what I did I used some thread lock on the new bolt. I’m just want to make sure for the front brakes. Because I remember they are a lot more torqued. I better buy a extra set of bolts and pins for the front. Just in case
Precision Instruments split beam torque wrench.
I was looking at it but I need to do spark plugs after the front brakes they need to be torqued about 10-14 ft/lbs the 3/8 lowest is 20 for/lbs ? I saw that husky had a new one plus it has a lifetime warranty anyone familiar with it?
Your friend has shared a link to a Home Depot product they think you would be interested in seeing.
3/8 in. Drive Electronic Torque Wrench
Precision Instruments also makes dial type torque wrenches that read in inch pounds. I have one that reads 0-600 inch pounds, which translates to 0-50 foot pounds.
I have a 1/4 tekton wrench that reads inch pounds I might just use that for the plugs. Just convert it to ft/lbs. and get the precision instrument one
