1 - 2 of 2 Posts
· Registered
i got the pilot lx...and it only came out w/ 4 speakers...my plan is put a sub where it's located on ex models and 2 tweeters on the dashboard...my question is..has anyone tried this one yet on their lx? where did you put the amp for the sub? under the drivers seat?
· Registered
Tweeter and Amp
A good location for mounting you tweeters will be in the upper right hand corners of your door where it meets the dash. Installing tweets in the dash can be a difficult affair due to accessibility. I would reccommend mounting your amp under the secon row seat ... I have always felt it is better to mount the amp as close as possible to what it will be connected to not for any other reason than installation ease and having to tear less up and run less wire than if mounted anywhere else. Hope your install goes well.
PrG
1 - 2 of 2 Posts
