Hello, With our HOT Texas summer my family has noticed the ac hasn’t been working as it should. It gets cold!!! I believe it’s not recirculating the air. Button on and doesn’t seem to be working. It use to make a noise like something else turned on and more air would blow to recirculate. Here’s what we have done:
-Bought recharge kit only to return it cause it wasn’t low.
-cleaned out front fan
-check cabin air filter
And I’ve been trying to find something online with no luck!?
I’m hoping someone has an idea. Thanks for your help.
Not sure if we have the same problem but I also got no AC a few months back. What solved my problem is watching this video. Mine is 2010 Pilot.
Sent from my SM-G975U1 using Tapatalk
If AC blows nice and cool but recirc doesn't seem to work, then I would visually check the recirc operation. Fortunately the recirc motor and flaps are located right above the cabin filter compartment. So just drop the glovebox down, turn on car and climate, and then press the recirc button and see if it moves as it should.
