First, let's start with driver window doesn’t work. Got new regulator and motor connected still nothing. Checking power at master switch connector with Zapped a little spark. Heard a click under the passenger dash. Ignition in the off position.
Now... only the speedometer and rpm gage flux when the key is turned on. It starts drives and runs. It coded out a P0607 Control Module Performance but it cleared and has not come back.
Problems:
All the door locks not working
Keyless Entry
Headlights Turn on when started, but can’t turn them on when no power is on. Turns off instant when key turns off. Same with dome lights
All Windows not working now
The gage arms for fuel, rpm, speedometer, temp not illuminated all other instruments lights work.
It seems to drive fine no loss of power, headlights, brake lights, turn signals, wipers, all work. At this time the PCM code has not come back.
Your Thoughts
2005 Pilot LX
What Getfurious said.
You probably shorted something when you were probing the master switch.
