1 - 20 of 53 Posts
2015 Honda Pilot Ex-l 4wd modern steel metallic
So I was cleaning maf today when I stumbled across this. It is a stick in the tube that comes off the big tube near the air filter. What the heck is going on?
148952
148953
Discussion Starter · #2 ·
Also can't find the location of pcv valve.
Found location of pcv but looks hard to get at.
Edit your pic to point to your stick. Not seeing what you mean.
148961
148962
Er… Some disassembly required…
Anypne know if there is supposed to be something connected to that little hose of a plug that goes on it. Why would someone stick a stick in it? Should I pull it out?
Looks like the transmission breather hose. Whoever thought it was a good idea to stick a stick up there should have stuck it somewhere else. SMH
Discussion Starter · #14 ·
It's backside of airfilter tube
148980
Discussion Starter · #15 ·
My guess through searching is AT breather tube maybe. I'm going to pull the stick out. If anyone thinks I should not pull it out let me know. Research didn't show any plug in them tubes so I don't know why someone would put it in there.
Pull the stick out. I’d want any pressure buildup in the tranny to be able to use the intended escape path.
Discussion Starter · #17 ·
Looks widdled down purposely any reason someone would plug the breather hose?
148981
Looks widdled down purposely any reason someone would plug the breather hose? View attachment 148981
If someone had over filled the ATF at some point it might have been venting out this tube.
Could have had the vehicle parked a while and didn't want a dirt dobber building a nest in there. 🤓
Reactions: ConrodM
One thing for sure, it warn't born there.
Unlikely it was a factory install either. :)
Discussion Starter · #20 ·
OK after pulling stick these dash lights came on. After about three shut off and turn on the check engine light is still on. Getting it checked. But any ideas why pulling the stick would make it set off all those lights?
149003
1 - 20 of 53 Posts
