I don't know if it happened to yours,but worth taking a look.On mine,the plastic part right under the ignition has a lot of scratches from the keys.What I did was using velcro tapes(1 side only)stick aound the Ignition to stop it from getting worse.Same thing to passenger and driver side where the seatbelt buckles hang when not in used.Notice that every time you release you seatbelt,that metal part would cause scratches.
these scratches have been discussed before. It seems Honda uses a very soft plastic material. I have the scratches where the seat belts hit and also in the rear hatch area where I load and unload "stuff". I also where sure like for Honda to replace these areas with a tougher material. Maybe some one will have an idea.
I hear you, I will be using some sort of material to cover area where seat belts cause little nicks in the plastic. Velcro strips sound good, or some sort of sticky material that will look good on that area..
will have to shop around.
rob
If anyone finds anything that will polish the scratches out, please post it.
thanks
