I bought my 2019 Honda Touring end of April. Shortly after driving the car I noticed a squeak in engine compartment when I let up on gas or brakes applied. Mileage was less than 1,600. I took it into the Dealer in June. Dealer said it was transmission (FIRST REPAIR ATTEMPT) and ordered new transmission. Early July brought in the car to have transmission replaced. Honda Technical Rep said it wasn’t the transmission. Recommended to replace engine mounts (SECOND REPAIR ATTEMPT). Engine mounts were replaced. Squeak was still present. After extensive test drive, Honda said it was from A/C and Honda Tech said to perform deep A/C vacuum/drying (THIRD REPAIR ATTEMPT). After A/C vacuum/drying the squeak was still there. Honda Tech then said it was A/C expansion valve. But, Honda refused to replace the valve. They stated it “IS A NORMAL CHARACTERISTIC OF THE VEHICLE”.
I was told by Dealer that three other customers had complained about same squeak and they also found a new car on lot with same issue.
In July I contacted Honda Customer Care. In August Honda Customer Care told me my claim was denied and that the squeak in the engine – A/C - was a normal characteristic. Customer Care Rep indicated that they were handling other customer complainants with the same issue. My complaint was closed.
Since when is a squeak in a brand-new car a normal characteristic? If Honda really thought it was a normal characteristic why did they continue to try to fix my car. It wasn’t until they couldn’t fix it after three attempts and Honda refused to replace the A/C expansion valve that they decided it was a normal characteristic. I am assuming not all 2019 Honda Pilot Touring cars have this issue.
It is clear that many 2019 Honda Pilots have this noise issue that Honda refuses to acknowledge as a problem to the customer. They sold me a car with a known issue. Isn’t that deceptive selling?
Hey hab, in California there is a Lemon Law that forces the Manufacturer/Dealer to buy back or replace any new vehicle that has had the same problem and not fixed three times! Like three-strikes and you're OUT! in baseball.
Anyway, you should do some research to find out if your state has that and if they do, you need to reapproach Honda and the Dealer with that info and tell them secure an attorney if need be..
Keep us informed here and good luck!
