6 Passengers, and Pilot feels like it's fishtailing
5.4K views 32 replies 12 participants last post by  cintocrunch
So after having my Pilot for 19 years I finally got to use my Pilot for what it was meant to do: haul humans. I had a full compliment of people, as we drove to a party. While doing about 60 MPH on the highway, I noticed the car began fishtailing a little. This was a bit concerning, so I reduced speed. I've never felt the car do this before, but when it was just me and my daughter in the car, I noticed a little bit of rear sway as well, when doing about 75 MPH.
Any thing I can do about this, or is this normal? The front tires are 2 years old, and the rears are a year old. I also just had my rear shocks replaced (not the coil).
2005 Honda Pilot EX-L
223K Miles and counting...
As an owner of an '04 I'd say its not normal for the Pilot to fishtail at 60 mph. Are the tires a matched set? At 19+ yr some Pilots may have some rear end sag. A complete F+R suspension inspection should be done to identify any worn suspension components for example control arm and sway bar rubber bushings do crack, struts can leak and reduce stability etc.
#4 ·
I see that you live in New York state. Your '04 has probably seen 20 winters of salt and slush. I suspect that the rear subframe connections are rusting out, and the whole rear end assembly is getting loose due to corrosion at critical areas. IMHO, don't ignore the unsettling fishtailing that you experience, but bring your Pilot in to a trustworthy shop with a lift and have them check out the rear subframe and unit body for critical rust. If I'm wrong, so be it, and you have spent $100 for nothing. If I'm right, perhaps you will avoid an unpleasant experience when your Pilot rear axle comes loose as you drive down the highway.
#5 · (Edited)
I'll add a vote of confidence in STMech's answer. You can see the subframe mount pretty easily from behind the driver's rear tire as an immediate first step.
If it is fishtailing/swaying from this, you may also be able to replicate the situation by pushing on the C-pillar or rocking it from the roof rails. To a first-order approximation, the vehicle should rock (rotational motion), but not sway (horizontal motion) relative to the tires. In the meantime, I'd avoid highway driving, family in the car, and other big loads until you can get it checked out.
When you bring it to a mechanic, please ask for photos so that you can see what they see and, if inclined, share them here.
#6 ·
Rusted rear subframe mount, especially on the driver's side: I consider it a safety issue. Honda still considers it as merely a TSB. 😨
#8 ·
Hopefully the OPs vehicle is in good mechanical condition and the issue is just low recommended 32 psi tire pressure on soft sidewall tires that are trying to support 6 people and their belongings. Most standard load tires have a max inflation of 44 psi (I prefer tires with 51 psi), so it would be advisable to add a little more to get the sidewalls off the ground. With this much weight 36 psi cold should be enough to be safe.
Hopefully the OP let us know the situation.
#9 ·
Especially when the vehicle is loaded in the back more and changing the alignment to a more of a positive caster. Looser steering is the evidence of having a positive caster.
And I wonder if air bags such as Air Lift and Firestone would help in handling?
Granted if all the rest of the suspension components is in satisfactory condition to begin with.
#12 ·
You have no idea how much this is all very much appreciated from the the Pilot family. Thank you all for the informative replies. I will take my OG Pilot in to get it inspected. I have had it on lifts this past summer when I got the new tires, and the rear, while it looked rusty, did not look as bad as the PDF file's pictures included.
- Will do. Thank you.
- Yep, NY, home of the salty roads. This is all reminds me of my '95 Pathfinder, where the entire subframe rusted out, while the top body stayed in pristine condition. The definition of sadness.
- Will do! Thank you
Ok, got it. Thanks
I am leaning here... as you say even light load (one person) you feel it.. a good inspection is in order as mentioned for bushings, spring breakage, poor installation, rust, etc... What were the shocks replaced with?
- I wish I had this answer. I requested new shocks, and was hoping that the mechanic would talk to me about the work, but instead they just installed basic shocks for the make and model of the vehicle. So, nothing great, but was definitely better than the factory shocks that were on the vehicle since '05.
- I'm not understanding this one completely. How does increasing the sidewall pressure help deter fishtailing? Also, I've noticed that when PSI is increased, the car usually slides more on cornering.
#16 ·
Ok, got it. Thanks
Honda say on the door jam that correct tire pressure is 32psi. This doesn’t work when loaded. The sidewalls may be touching the pavement (especially when cornering) and could cause the side walls to be damaged. This will cause a squishy unresponsive handling issue that can cause a loss of control. I’d keep inflating to firm up the tires, and not to exceed max tire inflation when the tire warms.
#20 ·
32 psi is way under for a fully loaded Pilot. Luckily the tire held together in that overheat condition.
I believe recommended loaded tire pressure should be listed on the sticker in the drivers side door jam. It also posted on the side of the tire what the max psi is with max load rating.
Yes, recommended is 32, but I have mine at 33, to account for temperature changes. But, still are you saying that if I'm fully loaded, I should increase the tire pressure beyond the recommended PSI?
Maybe just me, and I don't know if I am something of an outlier, but I just don't feel comfortable with my (relatively stiff Michelin LTX) tires not at 35 PSI, load or no load.
#21 ·
I run the Cooper Endeavors that came on mine at 35 PSI cold. Far too heavy a vehicle to run a lower pressure IMO.
...unless you're doing some offroad adventuring.
#24 ·
🎵... it's all right, it's all right [...]
Do it wrong or do it right,
It's all right, it's all right.*
*Except for tires, that is. 35 PSI. Too little or too much is not all right.
#26 ·
#27 ·
I think that guy was just trying to get the tire to 100%.
#32 ·
I feel a warm sense of validation when the normally stoic guys at the tire shop ask me what PSI I'd like them to inflate my tires to, I tell them 35, and they give me what as I interpret as a tacit nod of corroborating approval.
