Premium Member
Does anyone know where I can get just the external part of the wiring harness? my plug is all corroded and I want to replace that last section. I was also thinking about trying to wire a harness from the inside and just pull it out the back when I'm pulling at trailer (which isn't too often), that way I protect the plug from Wisconsin winter road salt.
Thanks...Dan
Thanks...Dan
Wal-mart has a small trailer towing section. They have this for $4.97 . It doesn't come with much wire.
136944
When you splice those wires on the harness together use some adhesive lined heat shrink tubing to cover each solder joint. I think you can even get heat shrink tubing with integrated solder to make it a one step process.
If the four pin harness is hanging near the spare tire, could you wrap it up with a plastic bag to protect it from road salt? Just keep it away from exhaust system.
Premium Member
Thanks...I actually already ordered and have a trailer wiring kit to get a new plug to put on, along with crimp and heat shrink tube connectors.
I was hoping for this part:
136957
vs buying the whole kit:
136958
Thanks again for any suppliers/retailers that might have just the final section.
Dan
Premium Member
To protect it going forward...I think I will use some of the dielectric grease on them. close the cover and put electrical tape around it.
