Sams has them for $119 each. They're just a bit taller and a tiny bit narrower than OEM's.
Any reason not to run them?
Super Moderator
If the are 75 rather than 70 they are slightly taller. In theory but even the same size tire from the same company has a different overall diameter.
You can run them. I'm using the same tire size on my 2006. I've never had a problem with them rubbing and it only changes the MPH by 1 MPH when doing 60 MPH. They shouldn't be narrower though, just slightly wider.
Discussion Starter #4
I pulled the 235/70's, 235/75,s and the 245/70s down and set them side by side then tread to tread. The 75's were definitely taller. They appeared slightly narrower, but it was marginal. If I try them, I'll let you know how they do. Thanks for the input.
