Comparing 2 models to each other isn't an apples to apples comparison due to different designs. With that said your pilot a/c sounds weak. There are pressure and temp charts in the service information to tell if the a/c is performing to design specs. If they take ambient temp, humidity, vent temp, and high/low pressures, they can show you on the charts.This will determine if it's operating in or out of specs.You can't tell me that story when one blows internally at 44 degrees and the other is 58 degrees.
I understand what you are saying. However as a consumer when you buy a car no matter which model, and the vehicle displays that my A/C or heater works at a certain temperature my assumption is, that the output temperature will be at that displayed temperature. Consumers shouldn't have to worry about will this vehicle work within the design parameters only if you live in a certain climates. There are complaints in Canada that some Honda vehicles will only blow heat up to 60 degrees when its -30 degrees outside. Their expectation is that vehicles output temperature should blow heat at 75 degrees if they wanted it to.Comparing 2 models to each other isn't an apples to apples comparison due to different designs. With that said your pilot a/c sounds weak. There are pressure and temp charts in the service information to tell if the a/c is performing to design specs. If they take ambient temp, humidity, vent temp, and high/low pressures, they can show you on the charts.This will determine if it's operating in or out of specs.
Someone mentioned newer Pilots have variable compressors. If that's true, "single" compressor kicks in 100% when turned on. "Variable" compressor adjusts output % according to temperature difference to conserve energy. Looks like your new Pilot has variable compressor.
We put a thermostat meter in to the center vent down 3 inches. This is how we measured both vehicles. I'm not sure about the windshield. In the shade we received the same results. Honda's techs received the same results with the thermostat gauge they use.How are you measuring 44 and 58 internal vs vent temp? Are both veh auto hvac, and both being compared in auto at the same temp? Are the windshields in either veh tinted?
Where are you seeing the temperature you are referring to?Again to me it shouldn't make a difference on design if the display shows a temperature as a consumer my vehicle should be able to produce those results
Depending on what part of Texas you are in, you can always go to any Honda dealer for warranty work which this should be covered under unless you are over the 36000 miles. There were some earlier model Pilots (3rd generations) that had leaks from the factory around or near the evaporator I believe. Has the dealership checked the amount of refrigerant in the system? My 2019 which I learned has the variable compressor (I believe on the Touring and up models only) has cold a/c. We have traveled through Texas and the deep south in extreme heat and never had a problem. I think it is something wrong with your system.We put a thermostat meter in to the center vent down 3 inches. This is how we measured both vehicles. I'm not sure about the windshield. In the shade we received the same results. Honda's techs received the same results with the thermostat gauge they use.
Again to me it shouldn't make a difference on design if the display shows a temperature as a consumer my vehicle should be able to produce those results. That is like selling me a car that says it will goes 100 miles per hour but really only goes 65. If car maker wants to say well that is the design and toss in a disclaimer showing all the parameters that is one thing. Then I as a consumer can make a more sound decision if I want to buy that car, because the climate I live in will produce poor results in that particular vehicle.
As it is I just found out that it does not Tow 5000lbs because its FWD. It only pulls 3500lbs. But do you think that make that disclaimer anywhere clear to consumers. Nope you have to do a lot of digging to find that out. You have to purchase the AWD in order for it to pull 5000lbs. Thankfully, I don't need to pull that much weight, but I do need the 3500lbs.
I think I, and others, are confused where you measured 58F and where 68F. As for vent temps, Honda doesn't state and you won't get a Lemon Law remedy on vent temps you are "expecting". And are you saying the system can't achieve and maintain a reasonable (70F) cabin SET point within 15 to 20 minutes of driving?I just bought a new Honda Pilot Touring and its AC output is pathetic. Its internal AC vent temperature doesn't go below 58 degrees making the actual output temperature around 68 degrees.
On the dashboard settings.Where are you seeing the temperature you are referring to?
If your wanting the air coming out of the vents to be that exact temp, your going to be disappointed. Auto hvac will vary the temp based on what it thinks it needs to keep the cabin at that temp. Factors including, outside temp, cabin temp, cabin humidity, sunload, and veh mph all effect the vent temp.On the dashboard settings. View attachment 160379
Disappointed is an understatement. If I wanted the cars opinion I would have asked for it. At this point is where the smart cars are doing consumers no favors. Maybe they should change the dashboard so consumers have no temperature options, instead put in a Magic Eight ball button that constantly says "sorry not today", or Try again tomorrow.If your wanting the air coming out of the vents to be that exact temp, your going to be disappointed. Auto hvac will vary the temp based on what it thinks it needs to keep the cabin at that temp. Factors including, outside temp, cabin temp, cabin humidity, sunload, and veh mph all effect the vent temp.
Good catch!Your pic shows RECIRC is OFF.
