Any one throw these wheels on you 04 to 08 pilot? Looks like it will fit according wheel-size.com
Takeoffs from new 2021 Honda CRV EX-L New 2021 Alloy OEM wheels manufactured 2020 week 44 New 235/60 R18 All Season Bridgestone H/L ECOPIA 422 18" Plus Tires TPMS Rim Size: 18X71/2J 45 Bolt Pattern: 5X114.3 mm Replaced by custom wheels
148069
I like those wheels on the CR-V, I think they'd look good on the Pilot. The only concern I would have is if for some reason they are not designed and built to the same weight capacity as the Pilot wheels, could they be more prone to bending.
Looks like 08 pilot is ~4500lbs versus 20 CRV is ~3500lbs.
You have to look at the maximum GVWR for both vehicles and the maximum axle ratings to really compare the load... But that does not mean the CR-V wheel is not capable of supporting such load and I am not sure how to confirm or deny this...
