Hello Todd,
If your still under warranty, your at the right place.
What is the year model and trim level?
Did you purchase the vehicle new?
Often times one issue can cause multiple lights to appear, so it’s likely it’s just a single issue and not all those warning lights is a problem.
Just the way you described things, my gut tells me that it could be an oil pressure sensor switch issue. This can throw the vehicle into limp mode. If your not someone who DIYs, you did the right thing to park it and get help. An OBD II scanner will be used to retrieve the trouble code.
