1 - 2 of 2 Posts
2019 Pilot EX. Touchscreen goes completely staticy/snowy anywhere up to 1 or 2 minutes then corrects itself without any intervention. Looks like the old TVs when you flip to a channel with no signal. Once in a while it is accompanied by crackle/popping sounds from the speakers. Dealer replaced the instrument panel wire harness but started up a month or so later once again. Happens 1 or 2 times per week and typically on the first drive of the day. Anyone with suggestions? What should I tell the dealer?
Thanks in advance for any help.
Seth
Seth, I would suggest telling your dealer the same thing you say here. If possible, have visual documentation as well. Since the issue could be infrequent and unannounced, it maybe difficult to capture it when it starts to 'act up'. Typically a full reset and/or an update of the firmware could fix it.
1 - 2 of 2 Posts
