1 - 20 of 28 Posts
Dash Cam - Sound ON and you can hear the crunch/judder a few times
2019 Pilot EX-L
50,000 miles
Prior transmission troubles caused dealer to drain and fill transmission around 40,000 miles
Yesterday, at 17mph (and almost exactly at 17 mph every single time) the vehicle felt like it couldn't find a gear and would lurch. It felt like the engine was going to clunk out of the vehicle. I pulled over and turned it off and then restarted and it didn't happen like that anymore.
For a while now I've noticed that downshifts are really harsh coming from gear 3 to 2 or 2 to 1. Upon downshift the vehicle lurches forward. But I don't know if it's related.
I took it into a dealer yesterday and the service tech made a note in the computer and watched the video but didn't do any diagnostics, and didn't look at any setting other than the mileage. (Perhaps because it's a drive train issue that would be covered under warranty and they wouldn't make as much money??)
I've seen there are some TSBs about similar issues, but maybe I've missed something.
ANY Idea what caused the clunk? Transmission? Torque Converter?
That's bad. Ask for a new transmission.
Reactions: RegularGuy
They didn't even take it in to do a diagnostic on it. I'd love a new transmission. How do I go about getting covered under warranty? (Drive train warranty is 60,000 miles - so it has to be in the next 10,000 miles)
What's recorded in your video is proof of that the longevity of your transmission has come into question. Ask for a new transmission or warranty on it as long as you own the vehicle.
Ask to talk to the service mgr, show vid, take on test drive if you think you can reproduce the issue. If they aren't receptive ask for the regional rep. to contact you.
You don't mention if any CEL or transmission warning light was displayed. If a transmission related CEL occurred, this should be in the computer memory, and the dealer can retrieve it. However, just because nothing is stored in vehicle memory, that does not let Honda off the hook. Slvr7 has good advice. Document your experience, and press Honda to correct the situation.
After I pulled over and restarted it the issue didn't return. At least not like in the video. I didn't know it might be stored in the computer.
No lights. No check engine or transmission lights.
Vcm and enginemount issue?
If you look up vcm issues there is a clunk some people experience at low speeds when the vcm is activating or disactivating which then i believe the engine mount are used to do this
When i read up on this i think people ended up having to need new engine mounts and a vcm muzzler to fix this or just a muzzler to stop the clunking
Discussion Starter · #11 ·
I highly doubt it's a vcm issue... Very highly doubt that vcm was engaged. Just call it a strong feeling...
If you are accelerating very much, the VCM is not engaged, at any speed.
Reactions: MtMan and ls973800
You can't continuously accelerate. The VCM will activate.
Nail Grease just go with the assumption that VCM was not engaged. I think he kind of means it like a Dominion guy saying he has a very strong feeling that Biden will "win" the election.
Ok 🤦‍♂️, well, but,
What goes up must come down.
Reactions: The Todd
Of course my friend. I meant that if the noise was when he was accelerating from a stop, I don't think it would be in VCM mode?
Reactions: Nail Grease
Discussion Starter · #16 ·
Update: the headliner by the rearview mirror is soaked after a rain so I'm taking it in again tomorrow and going to ask them to fix the transmission (or whatever it was) while they have it.
Why don't you Trumpies go drink your Koolaid somewhere else. This site is about helping people with their Pilots.
Its got a warranty, Honda problem. Sounds like a very very rough shift to me. Please let us know what Honda decides to do....
Discussion Starter · #19 ·
Anyone have any suggestions? I'm on my way to pick it up after the service tech says it's not "throwing a code" and they cannot reproduce the error.
Is there a printout of tests I should request?
There's just no way this is normal.
1 - 20 of 28 Posts
