New to the Pilot forum but have done a little researching answers before I posted.
I just bought a 2019 Honda Pilot EX-L AWD and have some questions on towing.
I plan to install the Honda hitch and harness but will also get our mechanic or Honda to install the ATF cooler to get the 5000 Lbs towing.
Is anyone towing the following with Honda Pilot? It looks like the Pilot can tow theses but wanted some real life experiences.
Rockwood 19FBS (dry hitch weight 413 lbs UVW: 3860 lbs CCC: 898 lbs Axel 2564 lbs GVWR 3913)
Rockwood 19FD ( 390 , 2829 , 1061, 2564 , 2980)
Flagstaff E-Pro 19FBS (same as Rockwood)
Flagstaff E-Pro 19FD (same as Rockwood)
Are you using a weight distribution and sway control?
What are you seeing for your tongue weight?
How does your pilot handle the load, terrain, off-road, strain, mileage?
Thanks in advance,
Thanks in advance,
