Were you using CarPlay when the system froze? Did you get “tuner not available” when trying the radio?
You can pull fuse 29 in the fuse box on the passenger side under the hood. You can also reset the system by plugging a USB keyboard into the CarPlay port at the center console. Plugging in keyboard then pressing ctrl-alt-delete has been reported to work.
Hopefully this helps fix the issue for you.
