Does anyone know how to reset the TPMS on the 2019? I can't find it in the menu anywhere.
It's not like some of the older Hondas. There is no reset in maintenance settings. Once the tire pressures are correctly set, just drive it. It will reset unless you have a bad sensor.
Discussion Starter #3
Reason I'm asking is because I bought a winter setup from tirerack and was wondering if i need to sync the tpms on that set to the car after installing it. So you're saying it would just work?
If you have changed to different sensors, then the new sensors will need to be programmed via dealer or competent tire shop.
