If you like them, you would love these SS3 LED Fog Light Kit for 2012-2021 Honda Pilot these. The lowest "sport" is really bright with a great beam pattern and spread. You can also get the aftermarket harness and run them with just parking lights and stay on with highbeam (unless there is a foglight MOD I didn't search for yet)I went with these from Diode Dynamics:
Fog Light LEDs for 2016-2019 Honda Pilot (pair)
and chose the yellow. The picture doesn't do them justice.
Trust me. They are VERY yellow and very authentic "true" fog lamps. Very happy with them.
Install was a breeze. Just go in from the wheel well. Wrap up and tie off the excess cabling with a nice cable wrap.
I secured each of the resistors up to the sub-frame with double-sided tape. No extra harnesses are required - those are only needed for LED turn signals. Once I put in the LED switchbacks
Switchback Turn Signal LEDs for 2016-2021 Honda Pilot (pair)
there will be a nice "stack" of lighting on each side of the Pilot during both day/night.
I looked at those but I don't trust myself with a Dremel to make them fit right without f-ing up something else. "Know thyself and STAY IN YOUR LANE" - meIf you like them, you would love these SS3 LED Fog Light Kit for 2012-2021 Honda Pilot these. The lowest "sport" is really bright with a great beam pattern and spread. You can also get the aftermarket harness and run them with just parking lights and stay on with highbeam (unless there is a foglight MOD I didn't search for yet)
$550.00 for the Max power? WOW!check this thread for the fogs. Others have done the same and basically screw in with the mount Upgraded 2019 Touring Fogs - Diode Dynamics
When I got the SS3 fogs for my sons Kia Forte I asked which harness. They said for the low power demand the 2 lights put on it, the light duty was what they recommended. That was what we installed. I always have one relay harnesses for my lights. Normally I modify switch wiring also so that the only thing going through firewall on them is the ground point to relay. If it shorts for some strange reason the worst that happens is the lights turn on and maybe kill my battery.
Light duty harness Light Duty Dual Output Offroad Wiring Harness
Heavy Duty Harness Heavy Duty Dual Output Offroad Wiring Harness
