1 - 10 of 10 Posts
When I accelerate from stop, the transmission jerks from 1st to 2nd. I took it to dealer and they said they noticed the jerk but refused to fix it as no codes were stored. They also checked automatic transmission fluid level. They said its normal to like models at this time and asked me to bring it back if any lights come up. Has anyone else noticed this issue and what's the resolution ?. Is it required that codes show up for dealer to fix the problem under manufacturer warranty ?.
Sorry that no one has responded to your topic. Transmission problems with new Pilots has been an issue and has been talked about here extensively. It's not surprising that your getting this response from the dealership on this issue. They are obviously putting you off for as long as they can. Know when your waranty expires. Don't cross that line without them admitting that you have a problem.
When I accelerate from stop, the transmission jerks from 1st to 2nd. I took it to dealer (Flow Honda) and they said they noticed the jerk but refused to fix it as no codes were stored. They also checked automatic transmission fluid level. They said its normal to like models at this time and asked me to bring it back if any lights come up. Has anyone else noticed this issue and what's the resolution ?. Is it required that codes show up for dealer to fix the problem under manufacturer warranty ?.
There is no fix for it. It is a very well documented issue with the 9-speed ZF transmission that has been present since it debuted in 2014 on FCA products. You will either have to live with it or get rid of the vehicle. I believe 2019+ vehicles deal with this issue by starting in 2nd gear most of the time. Just to save you the trouble you'll also notice the vehicle surges when manually doing to 5-4 downshift - this is associated with 4th gear being a dog clutch and the computer has to rev the engine to match the speed of dog clutch gears. The first time this happens (it feels like the car is speeding up momentarily while you are trying to slow down) it can be disconcerting. Again, this is working as intended.
To me on ours 1st gear just seems really
low, shifts smoothly but you’d think it was in 4wd low on my 4runner.
The first gear on the 9-speed is really aggressive.
No issue with our transmission shifting but yes, 1st is a low gear and really gets the pilot moving fast off the line. The gearing makes the 9 speed the faster and more
Efficient pilot over the 2011 6 speed in the cheap versions of the pilot.
What model do you have? If I believe the transmission issues are the 9 speeds, not the 6 speed transmissions. The 9 speeds in the 2018 was only on the Touring and Elite models.
There is an updated transmission software package for all 16-19 and select 20 9sp pilots.
Do you happen to know how new the update is? I try to get them when they come out but it has been at least a year since the last one if not longer.
1 - 10 of 10 Posts
