Banned
Just got a used driver side mirror. They told me it’s heated. The connector has 2 (linked) black wires (assume grounds)
and 3 others. My aim is to have a heated driver’s mirror in a basic LX
Pilot. I know i’d have to run/locate/
install a power supply & switch..
Can i assume the actuator motor wants 12 volts?
I would assume.
FYI, the factory installed heated outside mirrors turn on when the rear defroster button on the HVAC panel is pressed. There is no separate on/off switch. I guess you could perhaps pick up power somewhere and install a switch?
