HI,
Can anyone tell me what to look at to see what would cause that particular window button to NOT work. The other 3 buttons work just fine.
Thanks, Carol
Can you open the passenger window from that door’s switch?
Glad to hear you got it fixed. It would be helpful to post your findings (link) in case someone else runs into this problem.
Reactions: plplplpl
Might be this fix from the Ody club.
  • Turn car on with all windows up.
  • Using the PS window switch, roll down the window all the way and continue to hold the switch for an additional 5 seconds after the window is completely down.
  • Using the PS window switch, roll up the window all the way and continued to hold the switch for an additional 5 seconds after the window is completely up.
  • At this point the window Auto Up/Down function should work from the PS window switch and it should also now work using the DS window switch.
Reactions: plplplpl
