I recently installed the front leveling kit 1.5 lift and now i randomly get vibrations anywhere between 52-68 MPH. the crazy thing is it is not consistent it happens sometimes and sometimes the car drives fine any ideas what it might be. i checked under the car and everything looks fine no broken boots or any indication of bad suspension parts. anyone have any ideas what might be the issue i have balanced all wheels
First thing I'd do is retorque any bolts you removed or installed. Did you install new tires? If so, I'd get them road force balanced.
Are you feeling it more in your steering wheel or through the seat?
IFS/IRS vehicles can be tricky to install spacer lifts on, you start putting CV axles and suspension components permanently at angles they weren't durability tested at, increased the chance of wearing out parts or uncovering a worn part. My guess (if it's not new tires that need to be road force balanced) is one of the CV axles was on its way out and the lift revealed that.
