Got my 2017 Honda Pilot black box a day early. Thanks UPS! Heres a quick video of the first startup. Glad it was successful. It seems my theory was correct. Everything was plug and play. Vin number doesnt need to be entered. The anti theft keyless entry is the actually module that gives the OK for the headunit to run. At start up it will do a quick diagnostic test. Then I pressed the Power + Menu + Brightness button then a pop up an anti theft box asking to hold on to the power button to verify. After that it cleared and everything went through. All my old fm radio stations came back so it looks like a lot of data isnt even stored on the headunit.
Will update the thread when i do some more testing. any questions ask away.
https://youtu.be/74aw92kpXdA
*Parts*
2017 Pilot Black box assembly Part # 39542-TG7-A12
picked mine up from hondapartsnetwork for $852. search your favorite site or dealership as google search won't pop up most site parts catalog.
*Tools*
Plastic trim removal kit
philips screwdriver, power tool to speed things up.
Removal and install info can by found in my sticky post of service info.
search audio in the remove install folder
http://www.piloteers.org/forums/114...lot/118690-2016-honda-pilot-service-info.html
will make a video on how to remove the black box cover to separate main unit from the screen. Honda didn't properly describe how to remove the ribbons and i almost damaged the ribbon.
Edit: added comparison pictures
opening the box
front of the black box without a screen
identical ports
2016 head unit black box top cover removed
2017 head unit black box top cover removed
*Parts*
*Tools*
opening the box
identical ports
