tried searching, perhaps not hard enough....
Wife has a 2017 Elite. She pulled in the other night and I noticed her running light not working on the drivers side. Pulled the lamp and plugged it into the passenger side just to see if he light was bad but it lit like it should.
The harness and plug that plugs into the light also appear ok.
Ideas?
I installed my own running board (assume that is what you are talking about) and recall there is a fuse in the harness for each side of running board, you will need to locate that fuse. its been 3 years since I did mine, so, don't recall exactly where the fuse is but should be inside the kick panel. Hope this helps.
Nah, talking about the running lights that are on the lift gate, they wouldn’t have a separate fuse on each side would they?
