1 - 2 of 2 Posts
I'm a do it at home guy. Have repaired many things on many types of car... Trying to do a spark plug job on the 2016 Pilot... Is there a trick in getting the coil wires off? I feel like I'm getting to the point of pushing on where is says "push epdm" a bit too hard... (Turning a home job into a huge repair bill)... And nothing seems to be budging.
Thanks.
Thanks.
When I squeeze the release clip, sometimes I use a flat head screwdriver (with a gentle twist motion) to gently remove the conector. If you have all ready pulled back on the clip, you may need to push in first then press the release mechanism.
1 - 2 of 2 Posts
