2016 Honda Pilot Elite:
The DRIVER'S side Smart Entry (door unlocks when touching the door handle) has stopped working. When I unlock the doors via the fob the door unlocks. If I try using the actual key, it does not work either. When I try to lock the doors with the rubber button, it does not work. Inside controls work fine.
Everything works fine on the passenger side. All of these conditions are the same for both key fobs.
Thanks for any suggestions.
Sounds like you've tried to test and eliminate possible causes.
Only time I've had trouble with these systems was when I had my cell phone between the fob and car.
If you are still using the original battery in the fob, maybe it's time to replace it, if you don't hav e a phone interfering the signal.
